daphil
#1 Posted : Thursday, March 27, 2008 4:34:12 PM(UTC)
daphil
My HE 4t is giving a F33 error code. When it first started giving the code, it only did it on the sanitary cycle. Then, it started giving the code when I used normal cycle too.
My husband checked it for system leaks, but we do not see any. He also cleaned the filters on the inlet hoses. What could our problem be?
Thanks,
daphil
bambiblaster
#2 Posted : Thursday, March 27, 2008 5:02:31 PM(UTC)
bambiblaster
Remove the lower panel the tech sheet is there and lists all code and tests
