the heated dry light blinks continuously and the pump continues to drain whether the door is open or closed. it won't reset even after the circuit breaker was flipped off.
someone added a little dishWASHING liguid soap by mistake: about half and halh with regular dishWASHER soap so I'm sure that is the culprit.
any tricks to resetting?
My GE Monogram is doing the exact same thing. How did you fix it?
