SSP
#1 Posted : Saturday, January 9, 2010 12:42:51 PM(UTC)
SSP
Dryer starts and heats but will not continue to run unless the start button is head in or taped in. All other functions, timer, heat settings, buzzer and light work. Appears push button is not electrically latching.
#2 Posted : Sunday, January 10, 2010 1:10:58 AM(UTC)
Replacement parts for WHIRLPOOL GEQ9800LW1 27"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208541831.pdf
Sounds like your Push To Start relay coil is toast so that it is not holding the relay contacts closed once you release the button.
