my kenmore electric dryer will not start but i know there is power to the unit and the timer clicks when it put it on any of the settings but when i push the start button, nothing happens
please advise on trouble shooting this problem would help if you could attach repair/tech manual for this model thanks
Make sure you have 240VAC at the outlet. Sometimes half the breaker can trip, causing some things in your machine to work, while others don't. Go to the breaker box and flip the breaker for the dryer off then on and see if that corrects your problem.
I have checked the voltage at the outlet with a meter and find that there is 240v to the outlet.
