I am not getting any power to my dishwasher, I checked the breaker box and nothing was tripped reset all of them but still no power...any suggestions. Thanks
Check the connection box underneath behind the toe panel.. the wire nuts sometimes get loose.. there is also a fuse behind the console you can check it for continuity with the breaker off
It was the fuse behind the panel which cost $137.47 to fix. thanks
Why so much? The fuse itself ( AP3178588) is just $14.74 Gene.
