Just over a year old and the overload switch goes bad. Parts are not available so wondering if I can use the 3 in 1 start relay that shows up on the parts page. If I bypass the overload switch, the fridge works fine. Also, are all relay starts three prong plug direct to a compressor?
Thanks.
Originally Posted by: dougo  Just over a year old and the overload switch goes bad. Parts are not available so wondering if I can use the 3 in 1 start relay that shows up on the parts page. If I bypass the overload switch, the fridge works fine. Also, are all relay starts three prong plug direct to a compressor?
Thanks. 3-in-1 start relay can damage a newer compressor. Because this is barely new refrigerator, the best thing is to discuss it with Frigidaire. Gene.
I tried finding a part but Frigidaire says it is "not service-able" and there is no part to be ordered. That's why I am looking for an alterative.
That's very strange. I would call a pro for a final conclusion.
