Bigneasy
#1 Posted : Thursday, January 7, 2010 8:33:25 AM(UTC)
Bigneasy
I am running my AC Unit with the thermostat set on 70 degrees. The auto cycle is on and the unit is set for heating. The system currently runs for 8 minutes and shutdown for only 11 minutes. This is the continuous cycle of the unit. It seems like the unit cycle run time is excessive and I want to report it to my apartment manager. Is this a problem or is it normal?
hvac_hillbilly
#2 Posted : Thursday, January 7, 2010 5:26:56 PM(UTC)
hvac_hillbilly
if your running three cycles an hour with a run time of 24 minutes an hour thats not bad but to be sure what is the outside temp
