After I replaced my drain pump and belt it now clacks and wont turn the tub as well whats going on? jkl
You replaced not only the pump and the belt. You also replaced the central tub seal and one of many possibilities is you missed something during the assembly procedure. It's not possible to track it down.
Check transmission fluid level
