blainesr
#1 Posted : Wednesday, January 6, 2010 5:47:42 PM(UTC)
blainesr
have whirlpool electric dryer all of sudden no heat. replaced heating element thermostat and thermal fuse. checked all continuity checked all voltage. everything reading right still no heat. help please
#2 Posted : Friday, January 8, 2010 1:34:04 AM(UTC)
A Model Number may help other help you.
When you say the voltages are OK did you check them at the units terminal strip?
Be careful when doing this as 240 volts is lethal !!!
It is possible that the line cord is no good.
On most units if the heating coil, thermal fuses and all thermostats are OK, all that is left is a set of contacts in the timer and the centrifugal switch on the motor.
