acornelio
#1 Posted : Wednesday, January 6, 2010 12:30:54 PM(UTC)
acornelio
my dryer was working yesterday but it started to squeek realy bad and then it turned off with 12 min left in the cycle. i waited about 3 hrs and tryed to restart the unit and it did but the drum is draging on the back side and it is very hard to turn. i think it is the dryer suport shaft and support that are worn out. if so how do i replace it.
#2 Posted : Friday, January 8, 2010 2:06:58 AM(UTC)
Replacement parts for gew9200lwd models | AppliancePartsPros.com
Here is a manual that may be helpful.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
First I would run my fingers inside the drum at the front and rear just to check that something has not jammed between the drum and frame. Bra wires are notorious for this. Be careful, in case it is something sharp.
If OK you will have to open it up and find the problem.
Note: That often it is hard to locate the noise location re: sounds like it is coming from the back but in reality the origin is at the front.
You may as well give the unit a basic overhaul if you have to open it up.
Check all rollers, belt, drum seals etc for slop and wear. Replace as necessary.
Give the interior a good cleaning including the motor and blower wheel.
Also a good time to clean/check your vent system.
