:confused: This kitchen aid dishwasher is about 2 years old. It appears to be dead, however power is good from the wall, I checked with a meter. None of the control buttons light up or do anything when pressed; it is as if the unit has no power. Is there a fuse or reset button for this model and if so, where is it and how do I get to it??? Thanks for any help....
Originally Posted by: itpeterc  :confused: This kitchen aid dishwasher is about 2 years old. It appears to be dead, however power is good from the wall, I checked with a meter. None of the control buttons light up or do anything when pressed; it is as if the unit has no power. Is there a fuse or reset button for this model and if so, where is it and how do I get to it??? Thanks for any help.... please help same problem
