Aduckoutofwater
#1 Posted : Tuesday, January 5, 2010 12:39:19 PM(UTC)
Aduckoutofwater
The door is hinged on the bottom with a 1" long 1/4" diameter hollow pin that is mounted in a hole on an angled steel plate. The horizonal portion of the plate has two holes the same distance from the freezer when mounted, one towards the outside and one towards the center of the freezer. The pin is mounted in the outer hole.
To reverse the door I have to take the door off, remount the top and bottom steel plates on the other side, and flip the door upside down (because the door only has hinge pin slots on one side.) Of course, I also have to reverse the inside shelves but that is not the problem.
The problem is when I move the bottom metal plate to the other side I need to remove the pin from the hole it is in and and reseat the pin in the other hole in the steel plate, so the pin is towards the outside of the fridge.
I thought one good whack would free the pin from the plate and then I could just whack it into the other hole. No such luck. Despite enough force to almost damage the top of the pin, I could not knock it out.
Any ideas? I checked to see if I could buy a new steel plate but it is no longer made for this 15+ year old freezer. I presume appliance parts pros or Repair Clinic would have found one if they knew of an equivalent.
#2 Posted : Wednesday, January 6, 2010 4:11:21 AM(UTC)
Does not sound like this unit was ever meant to reverse the door.
Often they will use the same frame♦ etc. for both left and right door swing as it cuts down on the number of parts they have to stock in manufacturing.
I guess one way to tell for sure is if there is a lock receiver at the correct height on the right hand side.
Odds are that the pin is press fitted and then spot welded in. You will not even see the weld with contact welding.
All I can suggest is that you drill it out, tap the resulting hole, get a bolt and thread it in. Then either before or after you install the bolt grind down the threads till you get a stud of the correct diameter and length.
Or if you have access to a welder, drill it out and then weld it back in in the correct position. Of coarse this is dependent on if the stud will now be long enough.
Or the easiest would be just to drill it out and push a bolt in the other hole to hold it at the new position. The weight of the door on the hinge will probably hold it in place.
