Water is leaking from the lower right side of the water/ice dispenser trim on the freezer door. It is slow and is leaving a streak down the front. How do I find the leak and repair it? The diagrams don't show any water lines in the door. There is no water collecting in the tray. It is dry.
I have taken the cover plate off and water is coming from behind the stainless steel at the attachment hole. This is the second GE product I have had problems with. The first was a microwave that died after a year turned out to be a fan that was loose on the motor shaft.
