ShopToFundraise
#1 Posted : Tuesday, January 5, 2010 10:03:29 AM(UTC)
ShopToFundraise
Control Board seemed to lock up. Light stayed on and couldn't change from water to cube unless I removed the front plate and wiggled the grey wires connecting the 2 green boards. In the middle of the night the water came on and ran about 50 gallons onto floor.
I'm guessing the control board is all that would need replacing? Thanks for any advice on this side by side.
#2 Posted : Tuesday, January 5, 2010 7:32:49 PM(UTC)
Sounds you are right. very likely the problem is a bad control board.
- The control board Part number: AP4068159
