In attempting to fix a loose door handle, the exterior part of the door crashed to the floor and shattered the glass. I have managed to find a replacement piece of glass but would like to know what type of adhesive is used to afix the glass to the inside of the door. Thanks Colin
Hi Colin,
As far as I know, no adhesive nor glue used to assemble any oven door.
In case if any needed - it's usually included with a part.
