model is adg7005aww
squeaks very loud continuously..im guessing rollers or belt..question is how do I access the drum, or take apart housing so I can check bad parts, took off all screws but doesnt want to come apart Im missing something--thanks
You will need to take out the drum. This service manual will show you how. http://www.servicematters.com/m...ibrary/docs/16026315.pdfI strong suggest you replace the idler assembly and belt at the same time. Also take this opportunity to thoroughly get the lint and debris out of the cabinet and internal and external vents. The you should be good to go.
