mcslim40
#1 Posted : Tuesday, December 29, 2009 3:10:06 PM(UTC)
mcslim40
My gas dryer's burner will not stay lit. It will heat up at first for about 10 minutes, then the flame will go out. If I try to re-start, the igniter will glow to re-ignite, but the gas won't turn on. This will be repeated without ignition. Would this be a faulty sensor, or a bad gas valve assembly?
Thanks in advance
Greggy_D
#2 Posted : Tuesday, December 29, 2009 8:17:43 PM(UTC)
Greggy_D
Just went through this.....replace the coils.
