tstewy7
#1 Posted : Tuesday, December 29, 2009 10:59:44 AM(UTC)
tstewy7
Hello I have a Maytag Atlantis washer. During the spin cycle it makes noise, but it does not actually spin. The water drains but the clothes are still soaking wet. Can anyone help?
#2 Posted : Tuesday, December 29, 2009 12:54:59 PM(UTC)
Tilt the washer back. Remove the belt and check it. Make sure the pump pulley is moving freely in both directions.
Measure the voltage to the washer under a load. It should be 120 VAC ± 10%.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV6300AWW Washer, Atlantis | AppliancePartsPros.com
Help with maytag washer (Washer Repair)
by topcop12 5/5/2017 3:58:36 PM(UTC)
Help with Maytag washer (Washer Repair)
by woodman1 8/30/2009 3:48:05 PM(UTC)
