pal2393
#1 Posted : Tuesday, December 29, 2009 7:31:25 AM(UTC)
pal2393
My ge dishwasher will not completely drain after cycle is completed. I see the water coming from the dishwasher into the sink drain but there is a about two inches of water left in the bottom of the tub and i am getting sick of draining it out by hand please help.
pal2393
#2 Posted : Wednesday, December 30, 2009 10:31:53 AM(UTC)
pal2393
bump to top
#3 Posted : Saturday, January 2, 2010 3:17:05 AM(UTC)
Here are your parts, I used the 00SS
Replacement parts for GSD5560SS models | AppliancePartsPros.com
First check that the wash/drain solenoid (left hand side of the pump assembly) is operating correctly, pulling all the way down.
Next check that the drain hose is clear of debris, especially where it attaches to the house plumbing, stuff likes to catch and build up here..
Next and the most likely but hardest to check is the Piston & Nut (Item 564 in Section 2). It is under the cover at the back of the machine. Also it unscrews. Remove it and check it, if it does not seal correctly replace it.
GE Dishwasher won't completely drain (Dishwasher Repair)
by patrick0525 10/15/2009 10:49:33 AM(UTC)
dishwasher won't completely drain (Dishwasher Repair)
by bruneto 10/17/2008 9:57:25 AM(UTC)
