shermdo
#1 Posted : Monday, December 28, 2009 8:53:52 PM(UTC)
shermdo
The freezer and fresh food compartments were not cooling properly. I removed the back panel at the bottom of the unit and discovered that the DC Cond Fan (Part Nbr: AP4265957) never runs. The blade turns freely if you spin it with your finger.
I am prepared to order a replacement fan motor but would like to have advice troubleshooting this issue. Is it probably the fan motor or could the root cause be else where?
Thanks in advance.
shermdo
#2 Posted : Friday, January 1, 2010 11:49:38 AM(UTC)
shermdo
Well I received the replacement fan motor BUT it appears that may have not been the defect. The new fan motor does not kick on either.
I don't know what to do next in trouble shooting this problem. Any help would be greatly appreciated.
Thanks,
Don
#3 Posted : Saturday, January 2, 2010 3:34:39 AM(UTC)
Probably a bad motherboard in the back of the fridg behind a metal cover. Remove the board and look for bad solder joints by the power relay. If ok, order a new motherboard AP4436216.
