negrell
#1 Posted : Thursday, March 20, 2008 7:36:11 AM(UTC)
negrell
Tub fills with water but doesn't go to the next cycle, you can hear the the lid switch make contact and the timer is buzzing. I found a part called "Actuator catch lever" (p/n AP2044599) on the ground under the washer which is part of "shifter assembly" (p/n AP2045698), could this missing part be causing the washer not to cycle? The part is not a stock item, 7-10 days. I think I have all the parts to reattach the lever and 2 springs to assembly. Also, found oil under the wash machine.
negrell
#2 Posted : Friday, March 21, 2008 12:20:41 PM(UTC)
negrell
Any idea if the condition described below is causing my problem of the cycle not starting? Please advise, posted yesterday morning.
