#1 Posted : Monday, December 28, 2009 10:58:34 AM(UTC)
The first thing I would do is turn off the oven circuit breaker for a few minutes.
If it would not help, open the control panel and unplug the control panel ribbon cable from the control board. Clean it with a pencil eraser. Check the tracks in the ribbon cable for a hairline cracks, using a magnifying glass. Clean the connector on the board, using an electronic contacts cleaner or isopropyl alcohol. Be gentle and make sure it's dry prior to reconnect. Reconnect everything it give it a try.
If it still does not work, replace the control panel. If you need the correct part number, post the color of the control panel.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBS275PDQ6 | AppliancePartsPros.com
