I had a licensed repaiman eval, says maybe defective coils /leaky coils? or dust cover in back was missing? So I made a cover, next refrigeration coils get 1/2 frozen, 1/2 not stays wet ,( he says wait 2 days) is any repairs that can be done? or is th is a fatal diagonose and a doomed refrige:eek:
Rank:: Advanced Member
How long is refrigerator running since the repairmen checked it?
Put the rear cover and the back panel in the freezer back in place and do not touch anything for at least 24 hrs. Then check the evaporator coil and post your findings.
Today was checked its been 8 hrs with back cover on and NO food in her , Ice is hardend in freezer in tupper ware in 8 hrs ore less time. but fridge is still not super cold w/setting on 3 (or normal) cold will put thermostate in now will tell tommorrow am.
Need a good model # to help. Also, put a thermometer near the back wall of the freezer. Temperature should be between zero and ten degrees. If not you have system problems or a defrost problem.
Thanks Model# is 52534101 Kenmore 2001 yr. I have brought it inside -n- leveled it now seems 2 B working fine . ? now 48 hrs no problem ? It seems like levelin it did it? Or possibly the 12 pack of St Pauli Girl (no stocked inside) was what it was urning for? ;) I will keep posted new problems?
Refridge was working now only the noise of refridge comes on -n-lights but NOT cooling at all, I unpluged for 10 mins twicetoo no avail? What now ? repair man cant show upfor 14 hours from now? compressor doentkick in ?:( :confused:
We still need the right model number of the fridge.
I posted before sorry got missed , Its a Kenmore 2001 model # 52534101
Most likely the sealed (cooling system) is low on Freon. Also possible damage to the compressor. The cost of repair could be somewhere between $350 to $750 and it has to be done by a certified technician. Your decision should be based on the condition of the fridge.
