ronaldasocco
#1 Posted : Sunday, December 27, 2009 8:55:39 AM(UTC)
ronaldasocco
What is the icemaker auger motor voltage? Motor does not run, but have continuity through the motor winding. Would like to power up on bench to see if it will turn.
#2 Posted : Sunday, December 27, 2009 9:44:52 AM(UTC)
Should be 115 Volts, just check the printing on the coil. If it works, it may have frozen up or the armature rusted to the stator.
ronaldasocco
#3 Posted : Sunday, December 27, 2009 12:51:57 PM(UTC)
ronaldasocco
Thanks - I thought it was either 24 or 120 AC. Don't have a schematic. I will check it out pronto. Again thanks for replying!!
