Gene, the new HV Board installed as you indicated, but the programing instructions to move from flashing "PEO 000" by holding Door Alarm keypad and Freezer Temp Down - keypad, then releasing Door Alarm for 3 seconds, doesn't change the flashing "PEO 000" to "PE" for programing the code (0101 for this unit). The instruction sheet no. is 16026025. Your directions on installing were great, but now what do I do for the new programming mode? Thanks. NG
Hi Nick,
If you followed the instructions step by step and the new board did not work then probably the part is defective.
I would recommend to call the customer service to exchange the part due to the warranty.
