my dryer has a "pull to start" knob incorporated into the timer. In order to make the dryer start, I have to pull hard and off to one side on the knob. Do I need a new timer? Also, I have removed the top control panel and located a tag on the timer that has a whole series of numbers and letters on it but can't match it to any part number that I have found online. This tag reads 2295A Maytag 6 3720290 M285 Kingston 70770-A 01959 Any help or suggestions would be greatly appreciated. tks
My name is Demetrius Boudreaux and I am having a problem with my Hotpoint dryer. My dryer will not start at all. Earlier, I moved some lent from the back of the dyer and I turned it on. It came on. After finding out my knob was not moving as it was drying, I turned it off. I tried to turn it bax=ck on and it came on for a few seconds and cut back off. It did it for awhile and then it just stopped coming on. What do I need to do?
I have the same dryer with the same problem the part number is AP4043083 (33002803) timer number
