Hi New to the site and could use some expertise on my dryer.I think that the motor is shot and cannot get the blower seperated from the motor,is it threaded in?Do not find any set screws or nothing holding it
Figured this out,backwards thread,DUH!!!!! Also motor was not shot.I could get the shaft to spin but had to use a pliers to do so.Cleaned it out with copressed air real good and put a little lube around the bearings and started working it,pretty soon could move it with my fingers.Reinstalled works fine.
