I need to test the thermal fuse on the lower oven. I believe that it is bad. My question is how do I get to it. I have opened the access panel and can see it and might even be able to test it. But how do you replace it.
I could not find any information on the product with the model number you posted.
Verify the model number and repost it, please.
The oven is a double convection/bake. On the id tag on the inside there is a variation on the part number. ECPD230S but all other references that I have seen are just EPD230. Thank you
