I cannot find my model number in the list but I think the motor I need for a 11086870100 is the #279827. Is this correct and does the motor come with the motor switch? The picture looks a little different. Thanks, Rick
Is this correct and does the motor come with the motor switch?Yes looks good to me. I cross referenced it using a couple different manufacturer numbers. The motor switch is included. Part number: AP3094245
THIS FORUM IS DEAD!!!!!!! |
Thanks denman! do you know if the motor overload switch comes with it as well?
Yes, it is built into the motor |
does anyone have a wiring diagram for a kenmore 11086870100 electric dryer? Thanks, Rick
