My washer was filling then half way it stopped filling then would not run anymore. I thought it was the switch fuse so I changed it and it started working. I put in a load of laundry and it did not do anything, so I changed the fuse again and it started up again and went through a full cycle so I thought it was working so I put in a small load of laundry and it filled and stopped again. I tried again to change the fuse but this time it just wouldnt start. I dont know what to do:(
You need to do two things. First use a test meter to determine if the fuses are actually failing. You do this by determining if there is continuity in the fuse. Second post a full model number along with the results of testing your fuse and we will see what we can advise.
Be patient for a response, because of the holiday, and Happy Holiday Season to you.
Originally Posted by: sidfink43  You need to do two things. First use a test meter to determine if the fuses are actually failing. You do this by determining if there is continuity in the fuse. Second post a full model number along with the results of testing your fuse and we will see what we can advise.
Be patient for a response, because of the holiday, and Happy Holiday Season to you.[/ the model # is LAT3914aam and the fuses are ok
