sjf961
#1 Posted : Tuesday, March 18, 2008 3:23:59 PM(UTC)
sjf961
i`m getting a dlf [door lock fault] i took the front bottom panel off and located the lock. Can you tell me how to take the front top panel off so i can remove the lock. thanks in advance ,sjf.
bambiblaster
#2 Posted : Tuesday, March 18, 2008 5:57:09 PM(UTC)
bambiblaster
the lock is replaced by removing the boot sping in front using a small screw driver and pill boot away by the switch
