Originally Posted by: Gene  Hi Jeff, If the igniter shows no continuity than it is definitely bad and has to be replaced. I'm still suspecting the flame sensor too. - The igniter Part number: WE4X739
Gene. Thanks Gene and I have replaced the igniter yesterday, seems ok the ingiter glowed for 15 seconds then the flame lite up so pretty fast and I did watch it cycle numerous times. I did test the flame sensor, it did have continuity, but I have read it can still, as you have mentioned be bad. So I'm sure Ill have to replace the flame sensor. I do appreciate all of your help with this repair Gene, saved me a service call $$$....great site you have here. thanks again Jeff
You are welcome Jeff. We're glad to hear we could help you out.
