small freezer chest wont freeze. there is a green and a red light located on the thermostat panel, both light up, every couple minutes you can her the click of a relay down in the compressor compartment, but the freezer wont get cold.
Help please
Most likely the problem is a bad compressor.
The model number you posted does not come up.
