I've read other posts and responses on removing the front panel by prying it off. I'm using a 1 1/2 paint scraper to get behind the panel but it won't pry away. Created a small crack trying - :(. Any tips would be appreciated on how to get this off without further damage. Thanks
You can not remove the front panel because you tried to use a putty knife. Instead you have to use a small screwdriver. Insert a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED25DQXAW00 | AppliancePartsPros.comGene.
