hotpointdryer
#1 Posted : Monday, March 17, 2008 7:17:00 PM(UTC)
hotpointdryer
I took out the drum to get at the ("t-stat safe" part# AP2619437 -
it checked open. !) (The high limit tested closed.) Neither was grounded or smelled burned. The motor was not grounded and show 0 "ohms" between the leads.
What the heck happened. to make this dryer just quit and smell burned ?........
P.S. ( The breaker box is OK ) it didn't blow the breaker.
:cool:
johnl
#2 Posted : Tuesday, March 18, 2008 11:38:40 AM(UTC)
johnl
First off I'm not a tech. Perhaps... Heater element overheated, causing safety fuse to burn out (go open). If that happened, maybe because of a restriction in the ducting limiting airflow, or, bad high limit t-stat.
