Washer will fill with water, but no "tumble" of drum while filing. Pump will drain the drum, but motor won't spin. Door locks and indicator light is on. Removed belt and no motor spin. Followed steps on "tech sheet" for checking voltage at motor control board, all were good. Last step showed infinite resistance to motor. I replaced motor (ouch$), and still doesn't work. Mine is very similar to earlier posting by CNR "Kenomre front loader wont final spin", except my motor won't spin at all. Looking at the wiring where they tell you to check resistance, one of the circuits goes to the timer. The wire tested good from the control board to the timer. So after spending $200 for a motor, my question is timer or motor control board. BTW, I recently had to replace both "shocks" for the drum too. Thanks for any guidance you may lend.
Thought this might help too. TimVFR attached the following image(s):
