hmoorer
#1 Posted : Saturday, December 19, 2009 7:41:03 AM(UTC)
hmoorer
Rental unit dishwasher not filling w/water. There is a loose white wire coming from the water inlet valve. The pink wire leading from the inlet valve is properly connected I assume the loose white wire is the problem. What does the white wire connect to. A wiring diagram to/from the water inlet valve connetion would be helpful. Thank you.
#2 Posted : Saturday, December 19, 2009 12:03:18 PM(UTC)
Here is the wiring diagram you requested
http://manuals.frigidaire.com/p...df/Kinston/154371501.pdf
Dryer wiring issue - how do I properly reconnect wiring? (Dryer Repair)
by mdezrin 2/16/2022 10:53:03 PM(UTC)
Maytag Proforma Wiring Issues (Dryer Repair)
by Shak328 2/6/2015 6:15:14 AM(UTC)
Ignitor wiring issue (Dryer Repair)
by Hank22 7/29/2013 6:58:56 AM(UTC)
Maytag Performa wiring issues (Dryer Repair)
by Roarky24 10/28/2009 2:26:16 PM(UTC)
wiring issue, white wire hanging, don't know where it goes (Heating, Ventilation, and Air Conditioning (HVAC))
by ravennn929 2/17/2009 7:21:19 AM(UTC)
