GE double door refrigerator freezer --no water thru the door dispenser--valve ok--filter ok -- water pressure to the bottom of the door --ran a wire up door tube and hit a stop near the dispenser--is it possible tube is frozen--how hard is it to dissassemble freezer door Thanks JC
Taking apart the door is pretty serious job, especially the freezer door because of wires and water line inside.
The door has to be removed from the fridge first.
It's better to try to defrost the water line with a hair dryer.
