danr603
#1 Posted : Sunday, March 16, 2008 9:16:49 AM(UTC)
danr603
The over temperature alarms sounds regularly, but the refrigerator temp (37) is perfect. The freezer however is at least -10F. Air flow from freezer is excellent in that the temp sensitive baffle opens and closes as needed. I have increased temp control on freezer to +5, but doesn't seem to make much difference.
Shall I disconnect the alarm or do I need to replace something. If replacement is needed, where is the location of the item needing replacement?
Thanks!
