My whirlpool d/w filled the tub & nothing else. The lights on the touchpad pushbuttons work but it won't restart. I drained the tub manually & tried it once more. It did refill the tub again but that's all. I am mechanically inclined & have tools but am not experienced in d/w-appliance repair. Any help or tips would be appreciated? Or where I can find an online service-repair manual? Thanks, Steve
I found the fuse but when I am not sure if it is good. It reads 0 when I connect my meter to each side. Does that mean it is good or bad? If it is good, where to I go from here? I also checked the door switch, reading is 0. The float switch reading is also 0. Thank, Steve
