northerner
#1 Posted : Sunday, March 16, 2008 8:44:24 AM(UTC)
northerner
The bulbs underneath unit blew (now replaced) but the microwave fan, turntable, bulbs underneath don't work. The bulb inside unit works only if the door is opened, stays off if trying to m/w something. I found a fuse with wire connectors made right onto it and checked for continuity, seems O.K. Now what? Everything had worked fine until I tried to turn on the light!!
northerner
#2 Posted : Thursday, March 20, 2008 1:00:42 AM(UTC)
northerner
According to the local Maytag guy when the work top lights blow out like that it takes out the control pad/board. On a 7 yr old unit it is not worth repairing.
