FATBOYOHIO
#1 Posted : Wednesday, December 16, 2009 4:03:44 PM(UTC)
FATBOYOHIO
I am trying to find a part number for a thermal fuse foa an amana dryer Model LEA60AW. My dryer is not heating and there is no continuity on the fuse. Thanks
sidfink43
#2 Posted : Thursday, December 17, 2009 5:47:05 PM(UTC)
sidfink43
I assume you are talking about the one on the heating element case. That diagram is not on the parts breakdown, so I would call APP and they should be able to track it down for you.
See if this looks like what you need. If it is, go ahead and replace both.
Part number: AP4307250
#3 Posted : Friday, December 18, 2009 1:24:38 AM(UTC)
Here is a manual which should help
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
I would check the heater for a grounded element.
Remove both wires from the heater and measure it, should be around 10 ohms.
Then measure from each connector to the heater case, both should be infinity (open).
Also check that there is no flash marks on the inside of the heater case, as sometimes the coil can sag when hot and touch the case,
What happens is the heater can ground out and depending where/how it grounds it will run on high heat, the thermostats cannot regulate the heat and it will blow the fuse.
As sidfink43 said it is a good policy to replace both the fuse and the hi-limit as the hi-limit should have regulated the temperature so the fuse did not blow.
I would also check the unit's drum seals etc. The regulating thermostat is on the blower assembly so if there is a large air leak somewhere room air is sucked in. The thermostat then causes the unit to run on high heat and never turn off.
You may want to also check the operating thermostat. Remove it, place it on a stove element heat it up till you hear it open and then measure it. If it does not open it's contacts are welded together. Be careful you do not burn yourself. I just heat them up with my soldering gun.
As usual when a thermal fuse blows give the interior a good cleaning including the blower wheel. Also check/clean your vent system.
sidfink43
#4 Posted : Friday, December 18, 2009 5:59:34 AM(UTC)
sidfink43
Denman makes very good points, wish I had said them.
