I have a Whirlpool # ed5shaxmq00 side-by-side refrigerator (serial # sp4444484; manuf. date 10-03). By the way its age is about 4-5 years old. I recently ordered the water filter (in-grill type), part 4396508. I was told by Whirlpool and filtersfast that this is the correct replacement.
It does not seem to fit. It goes almost all of the way in, except for 1/4". It will not turn to lock in place. I shined a light in the filter hole. I did not see anything to impeed it, broken or otherwise.
It is almost as if it is too short. Whirlpool indicates that the part changed some time ago. I do not know why.
ALSO... I seem to remember having a difficult time of getting the old filter out. I turned the grill knob a quarter turn, then pulled out. It resisted at first but eventually came out.
Lube the o-ring with a little veggy oil the try
