Need to repair upper door latch but I swear the door is hermetically sealed. There are 3 screws on the inside door frame nearest the latches, but when they are removed nothing gives. I looked at the YouTube video on how to remove the choke cover, but this unit is not built the same. I thought I would post here before tearing into the thing and probably ruining the entire door. Thanks for any help you can give!
Please delete this post as I fixed the latch.
