I purchased the glass oven door part #11 on the door parts manual. Also puchased #12 and 14.
My question is does the #12 part need to encompass the actual glass door sides. My husband and son put it together but it doesn't look right to me with the outside of the glass door exposed. Please let me know if this is okay.
Hi elaine, As we can see from the door breakdown diagram the door trim side pieces (#12) and the door trim bottom piece (#14) are coming as a kit now with one part number for all three pieces. The NOTE for this kit says: "This part has been redesigned by the manufacturer. The lower screws are no longer used and the side trim now locks into the lower trim with the dimples on the lower end of the side trim." In order to provide the right part number for the oven door trim kit I need you to post the rest (one more letter followed by one digit) of the model number and the color of the door. Gene.
