jlrskymaster
#1 Posted : Friday, March 14, 2008 11:49:41 AM(UTC)
jlrskymaster
I posted yesterday but no response thought I'd try again.
The dryer motor spins the drum fine, and blower works ok, no restriction at vent outlet or hose. But, no heat at all
What should I do?
Matt S
#2 Posted : Friday, March 14, 2008 4:32:52 PM(UTC)
Matt S
Many possibilities here.
First thing to do is check the white plastic thermal fuse. If your dryer has the lint screen on the top of the cabinet, the thermal fuse is in the back behind the service panel. It is about 1 and 1/4 inch long with two wires. Check it for continuity. That is the most common problem.
Matt
