I have a Jenn Air double oven and the top oven takes a much longer time to heat up to the desired temperature than it used to. It takes longer when in convection bake mode. I sometimes get the F5 error code, but it goes away after turnining off and on again.
Originally Posted by: gkademo I have a Jenn Air double oven and the top oven takes a much longer time to heat up to the desired temperature than it used to. It takes longer when in convection bake mode. I sometimes get the F5 error code, but it goes away after turnining off and on again. F5 is a clock control error code. The clock control part # is Part number: 71001872R
Tom
