The bottom part of the heat source in the over is not lighting. No gas comes up when it turns on, but the broiler works in the top part of the oven. I have been told it's the "Cylinder" that needs replaced. I cannot find that part on the website and I wonder if it is the "oven igniter" I need to replace. This oven is a Caloric Prestige Series and the number I took from it is 35-302251-0.
