jfb
#1 Posted : 15 years ago
jfb
Having a problem finding out how to remove the knob from the timer housing without destroying everything. I need to replace the timer unit could anyone help me?
#2 Posted : 15 years ago
The instructions are printed right on the back of the timer. I think you push the knob in, then in the back of the timer you use needle nose pliers to pull the retaining shaft out.
jfb
#3 Posted : 15 years ago
jfb
Thanks for the reply. There is no instructions on the back of the timer but i will try what you have suggested.
