tipp
#1 Posted : Friday, December 11, 2009 9:55:39 AM(UTC)
tipp
The oven lights very slowly. The igniter comes on immediately and is very bright, but the gas valve does not come on for 5 to 10 minutes. Occasionally, there is a fluttering of the gas when it lights, I think due to partially open gas valve. Once lit, the oven tends to usually relight on it's own. If I reach behind the oven and gently tap the gas valve with a hammer it will light immediately.
I replaced the gas valve one year ago and it helped somewhat, but is now acting up again in the same manner.
Model Number: RB17AG-2A-'iB53A'
Ser #: DH30701037
Thanks,
Tipp
